Premiere crashes (boot.ini issue)
rawfa
Hi guys,
I have an AMD 64 Dual 3800+ and sometime ago I was asking people here how could I take my performance to the max, so somebody suggested making some changes on the boot.ini file. I did the suggested changes and to be honest I didn't notice any improvement...but now from time to time I'm working on premiere and the entire system crashes. The pc goes down like there was a power failure. I'm thinking that by enabling the system to use 3gb instead of 2gb (which is the original command on the original boot.ini file) the system overheats after some time, which makes it crash. Now here comes the tricky part. I had the original boot.ini file saved on my hard disk, but I had some serious trouble and it got deleted...not I'm stuck with the changed boot.ini and I cannot keep working like this.
Here is the changed boot.ini file I have right now:
[boot loader]
timeout=0
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
signature(83741ba5)disk(0)rdisk(0)partition(1)\WIN2="Microsoft Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(1)partition(2)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /3GB /USERVA=3030
If someone knows how can I manually change these settings back to the original to restore things to peace. I really don't know but I'm thinking the boot.ini file is probably the same for most. Anyway, any help will be appreciated.
Apparently it has nothing to do with the boot.ini changes I've made in the past. I changed them back to original and the error persists. I've just reinstalled premiere to see what's going on...but I'm almost 100% sure it's not this, because there's a couple of applications where this happens too (dvd burners, anti-virus). I hope it's not some mean virus.
Restoring the boot.ini didn't do anything. I DO think it might be something related to overheating. I removed my graphic card and reinstalled it again but no go. I also restored the system to a previous time that I save when everything was working and I reinstalled windows. Things are getting complicated.
I used to have 2 hard drives (300gb each) and now I have 3. Do you think this might be generating enough extra heat to make the pc shut down like a power outage? If so, how can I deal with it? Is there a specific cooling system to deal with this situation?
In the meanwhile I'm going to try removing the memory and putting is back in again.
This sucks, because I just finished editing a short film and I can't even export it.
I removed and inserted all my hard drives and memories, but now I cannot try premiere because when I restored the system it deleted some important stuff. It won't let me delete either. I'm going to make a fresh start and format my main HD.
Btw, I've downloaded Speedfan to see if it's a matter of overheating or not, but I never used a program like this before. I made a print screen of the results:
[img=http://img385.imageshack.us/img385/8417/speedfanresultsgr9.th.jpg]
I think 72C is probably not a good temperature.
Actually, if you look at the picture I've posted you'll see that the place where it puts 72C it says "temp3" (which I have no idea what it is). But the temperature on the hard drives is between 32C and 41C (which appears to be correct). What I really want to know is what the heck is "temp3". All the other temperatures seem to oscilate while I monitor them, except "temp3". I don't know if there's any SPEEDFAN users around here that can give me a hand with this...
My pc came with a tool to monitor and control this. It's called Easy Tune5 and when I go to "pc health" I have the following options:
___________________________________________________________________
FAN LOW LIMIT
CPU-->2000 rpm
System-->1000 rpm
Power-->1000 rpm
TEMPERATURE TRESHOLD
CPU-->60c
System-->60C
Does anyone know if this is correct? I am allowed to change them.
