paulears
I've always synced by hand, but have a project underway where I've loads of clips, all with sound, that need syncing.
everyone says Pluraleyes is the way to go, so I was going to just buy it, but luckily downloaded the demo first. I'm using CS5 on a PC, and the problem is that if I export the xml file from Premiere, or import direct, the files all display with media error, bottom right hand corner, and a yellow triangle warning - Error: audio extraction failed. This is on HD mpg and mts files and also SD avis.
The on-line results of my query from Red Giant, suggest drive permissions, and suggest setting the location of the temp files via the file menu, apart from the fact my version has no such menu item.
Google suggests it's a common problem, but no answers to the problem seem to be around. I'm pretty glad I didn't buy it!
Has anyone cured the problem? I could download the trial on my MAC, but then I will have to copy many Gbs of files across.
The less time you have available, the more annoying these things become!
