Premiere 6.5 Question
RaySigmond
When using Premiere 6.5, how do you eliminate the flicker or strobe when slowing down the image that was recorded in 30 fps?
Re: Premiere 6.5 Question
Right click on your sloweddown clip and go to field options. Then just uncheck the frame blend speed changes. I think that should do the trick. Or you can do the same and click flicker removal. How slow are you making your clips? hope that helps.
