Pre Render files.
JohnT
I have a ton of pre render files from this wedding Iam editing. Can I just delete them and after several more edits do a pre render again just to check my transistions. Aso which one to delete? Unactive, all prerender, or the ones within the time selection? ???
Re: Pre Render files.
Under the Tools dropdown, choose "Clean Up Prerendered Video."
If you're pre-rendering every time you're checking a transition, there's no reason to keep the old pre-render files. In fact, once it disappears from your timeline (if you make a change, etc.), you can get rid of it, because a new pre-render won't reference the old pre-render.
I noticed that once I deleted the Pre render on the drop down, the files are still showing up in my explore tab. I guess I could just highlight those and delete them???
Try right-clicking on a white area of the explore tab and selecting "refresh." If the pre-render files have truly been deleted, then they should disappear. The Explorer tab doesn't auto-refresh.
I had to delete them by highligting them all. Tryed the refresh, but that didnt worked.
