PPro CS3 3.1 standalone update now available
Hi Guys,
I just start playing with Premiere CS3. Is that the Keyboard Shortcut changing from previous version? I've just run into a Premiere 1.5 video tutorial on keyboard shortcut: Jacob Rosenberg. He using the following:
Ctrl- ` Toggle Source Monitor/Program Monitor panel.
Ctrl-tab Toggle between all the panels.
Also He assigned custom keyboards
Ctrl + 2 for Source Clip: Next
Ctrl + 1 for Source Clip: Previous
Ctrl + Backspace for Source Clip: Clear Clip.
With CS3. All the shortcut doesn't work for me. I also looked inside Edit> Keyboard Customization but couldn't find them.
Any advice?
Thanks.
Hi Guys,
Any advice?
Thanks.
Ctrl- `is gone and replaced with individual shortcuts for each panel and that makes Ctrl+TAB unusable. The shortcuts for the Source you mention was for some odd reason left out in PPro 2.0/CS3 and i do sure hope that they will be back in CS4.
The shortcuts for the panels can be found in the Window menu or under the Window Command in Edit > Keyboard Customization.
/Roger
