PPro 5.5/MBL
james thorpe
Just wanted to double check this with you guys...
Is MBL1 not compatible with the latest Ppro5.5?
So you have to upg to MBL2 to work? I don't see Magic Bullet in my effects menu
when i upgraded to 5.5.
Thanks much MMKA. This works if you use MBL in AE but not for Ppro (if you d/l for Premiere option).
I tried re-installing my v1 MBL to AE and i can't find any Mediacore folder as was mentioned in the YT video. :(
Where is the MBL plug in located? RedGiant sent me a link for an installer but thats for v2 version. So, i'm kind of stuck..
For Premiere, you will have to copy and paste your plugins in the contents folder of the Premiere Pro app. You can access that by right clicking on the Premiere app
I'm using Mac Ann. Thanks. Still no luck.
When i go into the Premiere CS5 folder, in Mac, all i see is a 'Configuration' and 'Preset' folder. There is no Plug-in folder.
Inside the 'Preset' folder is 'Styles', 'Templates' and 'Textures'. The only plugs i use are MBL. They must be somewhere else.
Don't want to bug you too much,...i'll just have to upgrade to MBL2. For now, i can edit and use MBL in 5.0...export. Then import the file into 5.5 and apply Warp if
i need to.
Did you follow the video that Michele Yamazaki did for Mac. Follow those instructions. They work.
