Looking at a cheap field mixer on ebay - Marenius MM-3100 Portable Mono Field Mixer, the specs say that the phantom power is equal to battery voltage!!!!!
(that's why it's so bloody cheap right)
Internally the mixer takes two 9v batteries so that will be 18v for phantom power which will not work with my 48v mics - some newer mics can run on lower voltages but I'd like 48v.
Can I use a phantom power adaptor and just feed the 48v to the power supply of the mixer - (NOT TO THE MICS AS these units are normally used)?
Say this guy --- http://www.sweetwater.com/store/det...ampaign=none&gclid=CMvhy9KGrrICFQVgMgodyS8Abw or something similar? Looking for a cheap solution as I don't want to throw down the $$$ for the SD 302 just yet.
