Powered FireWire Drives
moviemaker999
As most of us know, the p2 cards are very expensive. Having a portable battery powered firewire hard drive is exactly what you need for offloading p2 media to hard drives. there are very few of these, but all it is is a hard drive case thats battery powered and [FONT=Verdana, Arial, Helvetica, sans-serif]You can purchase and install any 9.5mm/ 2.5 inch laptop hd 10G, 20G, 30G, 40G, and the new IBM 80G Travelstar laptop hard disk drives. You can find this item at http://www.firewiregear.net/productdetails1.cfm?sku=AMS25K&cats=
For only $78 then purshase a cheap hard drive and whala. you could go the ipod route, but at usb it will take a lot longer and its more expensive. for about $ 200 you could be transferring p2 files to hd. The Hvx200 basically formats the drive as a p2 card so it pops up on your computer the same way a normal p2 card would. The only thing before is purchase a p2 card, then your set,unless you would rather transfer to a laptop. Obviously you could purshase the FS-100 which cancels out the p2 card permanently and records the video from the camera directly at the sime time, but its $2000. Now, some people need continous recording without waiting for transfers, but I can spare about 1.5 minutes per gb( depending on how fast your hd is/ eg. 7200, 5400). so I hope this article helps you, but I know i'll be using the external HD. Thanks.:shocked::shocked::shocked::shocked::cheesy::cheesy::cheesy:
[/FONT]
I've got that enclosure. The battery only lasts for about five 4gb offloads before it's drained, so it's of very limited usefulness.
Thanks for that explanation, but how is your experience with the lasting of battery? Barry obviously made other experiences. So you never can use a 8 GB P2 card? Battery powered means changeable Batteries?
Benn
Have you tried it on a 8gb card? I wonder if i could even use it on one 16gb card.
