If I needed one, I would make it. Just take a 9V battery apart and solder wire into the terminals through a hole in the case. Reassemble without the guts. Connect to a powersupply, or a big battery. If you know what you are doing and have the parts handy you are talking about maybe 15 minutes.
I think there's more to it than that, though. You'll need some components in there to, correct? I've sold some of these battery eliminator kits, and there's always a little board in there with components on it. Units that run on 9V batteries are used to getting that and not a direct 12V. I'm not an electronics expert, though, so I could be wrong. It's not something I'd do without really knowing what I'm doing.
Whatever you do though you do NOT want to solder wires to a 9V and then run power to it. Nor do you want to take one apart, there is some nasty stuff inside.
By the way, in a typical 9v battery there is zinc and carbon. Nothing scary or dangerous.
You may want to do a search on "9 volt battery eliminator"
Something like this: http://www.batteryeliminatorstore.com/index.php?id_product=8&controller=product
would work with out modification.
