Possible to upgrade FS700 UK firmware version from 2.0 to 3.1?
alexandernilsen
I'm borrowing an FS 700UK. At the moment it's upgraded to 2.0. I've tried to upgrade to 3.1 but it's not working. I got the upgrade from here: http://pro.sony.com.au/pro/support/firmwares/1237493297313
The reason I'd like to upgrade is because I want to use S-log 2 for best grading results. I'm also using it as a second camera together with the c-100, probably not the best match but this is what I have access to for now so trying to get the best results.
I've also tried to look for the s-log in the current picture profiles but can't find it. I also can't find any tutorials online on how to select s-log. Maybe the answer is obvious but I can't seem to find it so please excuse my ignorance. Does the 2.0 version come with s-log?
Thanks!
Only version 3.0 comes with SLog2 alongside the 4k upgrade. But you can't upgrade to 3.0 yourself, you need to send it to Sony for the modification. Once you have 3.0 you can upgrade to 3.1 via software yourself.
So if you have Slog 2 on your camera that means you have the 4k upgrade?
