So i've been trying to figure some tech issues out lately regarded dv and the 24p problem in PPro.
We know that the strobing problem when editing 24p in PPro is because particular frames that must be rendered (i believe its every 2nd and 5th) to playback 24p-standard have the white levels crushed to fit within "legal" limits (about 100 IRE).
When editing 24PA, this does not happen because the original 24 frames can be extracted without having to process any of the data (no mixed fields).
I also found that some DV codecs will allow to use the full black/white range of DV, and some will not. I believe a codec like Canopus will limit the range, where a codec like Quicktime will give the option to use limited or full range. This is the option in Final Cut Pro called "superwhite." If you turn this on, it will go above legal limits, giving the full range of what DV can handle.
OK, so... we also know that the dv codec in PPro is the Mainconcept codec... although I do not know which version. The newest version on the Mainconcept website to purchase is 2.4.16
But Mainconcept also has this press release ( http://developer.mainconcept.com/press-releases/dv-codec-244.html?pr=dv_codec_244)
stating that a version 2.4.4 which came out on July 29, 2003 supports the option for "clipped and unclipped black/white levels."
So, I foolishly purchased the Mainconcept DV codec, version 2.4.16, in hopes that maybe I can somehow access these options to use "unclipped" black/white levels.
I haven't been able to experiment too much, but I think the main problem will be getting Ppro to use the newer version of the codec, rather than the version it comes with.
In any case, if the version of the Mainconcept codec with PPro happens to support "unclipped" black/white levels, I would think there would be some option of turning this on. This way, there would be no crushing of the whites in rendered footage. (btw,this may be one reason why editing in QuicktimeDV on Final Cut may be superior to Ppro)
Regardless, this does not solve the problem of being able to use 24p footage as 29.97 and mixing with non-24p material.
If anyone actually read all this, I hope it makes sense.
