erniediaz
Hi friends, I want to share this with you and view your opinions.
If you are using a laptop (PC) in order to download you P2 content, then you can use a 2.5" USB powered HD or a USB OTG.
I have done it and no problems.
But I do have a better arrangement, I Use DV rack HD in a Pavillion Laptop, with an PCMCIA Sata card (this comes in MAc Version Too), hooked to a 2.5 Self powered Sata HD (made by myself)
I made a device with an Ipod 12 to 5v charger, an 3 Ah 12 volts Acid battery, a 80 GB Sata HD, a plastic box and a 2.5" Sata - USB housing (It is a 2.5 Sata/USB portable housing without the aluminuim case, just the circuit nd connectors board wich comes with the housing. )
See this:
This has become a must in my production gear!!!
I Have another equal but with Fire Wire instead of Sata, for download directly from my HVX, works fine!
Hope this post will help some body
Regards
See this:
Regards
