synapse
I use a Husky power supply when I need portable juice:Bucknfl said:Do any of these units work on battery?
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100096992&N=10000003+90401&marketID=401&locStoreNum=8125
It's a pain to be lugging around, so I don't think it's appropriate for true run-and-gun stuff, but I don't think a 15.4" monitor really is either. As David said, not very portable. If you'll be outdoors with a setup that doesn't require a lot of movement, then both should serve you if you're on a budget.
Caveat #1: I've never used one of these low-end monitors in bright sunlight yet, but I have a feeling they'll need a hood or some sort of shade. Mine isn't bright by any stretch of the imagination.
Caveat #2: the Husky power supply engages a small fan when the AC power is in use. It's not very loud (more of a low hum), but you'll need to keep it at a little bit of a distance to make sure it doesn't interfere with your sound.
--nick
