polarizer+ ana lens
bilgami
I was wondering what size thread is infront of the anamorphic lens to screw mount thread a polarizer?
:dankk2:
Barry's right, you need to use a mattebox in front of the anamorphic adapter to make best use of a polarizer. I have "rigged" a solution once or twice with my LA7200; I just put the polarizer in a filter holder (I used a 4" x 5.65") and carefully gaff taped it to the lens hood of the adapter after finding the correct rotation.
Not the most elegant solution, but it worked.
polarizer and ana
polarizer and ana
i kinda figured what size did you use for your rigged up solution i ask cuz i have a 105mm polarizer now and id hate to have to buy another one.
:dankk2:
I too have done the same as KHmuse... not very pretty either :P
105mm polariser is circular? sounds so. The 4" x 5.65" is a square (rectangle) pl .
A 4" x 5.65" is a standard rectangular Panavision size. You might be able to use a 4" x 4" as well if your are not too wide, same goes for a 105mm round.
