PluralEyes problem
liukaitc
update:
sorry for my poor english..
anyway I solved the problem by downgrade premiere pro cs5 to cs4
after I sync by using pluraleyes in cs5..the program monitor turns to problem as pic shows
I really HATE the ease with which one looses what one is typing with this new version of the board!!!
So the short version of what I wrote before is that I don't think either your english or the translation app you are using is up to the task of this kind of technical discussion.
I would suggest that you mention your native language and maybe someone who speaks it can work as a better translator or there maybe a list in your language that would be of more help.
Folks here are very willing but the translation is very confusing.
OR I'm just being dense and somebody else knows what your talking about...
But I think most will stop after failing to understand what your problem is and I'm concerned that even if they had the answer the translation would mangle it.
ye..sorry..my english not good...I can not help it......
can u see the pic I uploaded?
bascially...after I sync using pluraleyes and import the file, and then after I did some editing to the sequence...program monitor turn to that...
this is only happening after I sync using pluraleye..never happen before
put even more simply
after the right procedure of operating pluraleyes..the program monitor turn into trouble as my pic shows above..
as consequence..the video exported shows same image as the program montior shows..
anyway I am using free trial version..I think it is really a weird problem..it is like that footage after sync by pluraleyes become damaged..
ok...guys...I downgrade to cs4..and now everything is fine with using pluraleyes....
really weird problem....
Well I only speak one language passably so your way ahead of me. Pluraleyes may not be CS5 ready? I don't actually use it so that is just a guess. You may want to talk to the folks who make it since this sounds like something they might want to fix. They may also know what the problem was.
