Please help me get this straight...
MyFilmPro
Hello,
Okay so I've been reading and reading and I'm still not sure if I've got this all straight so I thought I'd lay out exactly what I have and hope that someone here can set me straight.
I've got a GH1 and I'm editing with the Adobe CS4 production suite.
For SH (720p = 60p) footage for slow motion I've been pulling the mts files directly into After Effects and using a 24p comp and timeremapping so that I can do a kind of "300" effect where the time slows down and speeds up in a fluid motion.
For FHD (1080p = 60i) footage I've been pulling it into After effects to do color correction and then render it out as an .avi to edit in premiere. I've also done it the other way around where I edit first in premeire and then bring the project into After Effects to CC and/or add any effects.
My question is around pulldown removal:
As I understand it, its only the 1080 footage that needs pulldown removal, correct?
And secondly, is Adobe doing this? And should I be using cineform or voltiacHD?
And what about the 720 footage? When I bring it straight into premiere it looks horrible, with weird interlacing (I think that is what it is - the edges are all pixellated), but into After Effect it looks fine. Do I need to do anything to the footage before editing it?
And lastly, am I the only one that edits using a PC and Adobe? It seems that almost everyone here is on a mac with FCP...?
Thanks.
I work with Premiere CS4, for FHD pulldown I use Cineform ( I don't think you can successfully remove pulldown in AE). 720p footage goes straight to the 24p timeline, if I need to slow or speed up my footage, I use Time remapping in Premiere its faster and easier for me, maybe I would get better result with After Effect but for now I'm only doing it in Premiere.
Your're right its only the 1080 footage that needs pulldown removal.
I have no problem editing 720p .mts footage in Premiere, but if I preview the source file in the window preview than it look very weird, otherwise footage drop in the timeline look fine.
