Please help! I am having some interlacing issues with footage shot on my DVX100B. Here's the skinny:
- The footage was shot on the DVX100B in the standard 24P setting (not PA)
- The miniDV tapes were captured in FCP with the following settings:
Vid Rate - 29.97fps
Frame Size - 720 x 480
Compressor - DV/DVCPRO - NTSC
Pixel Aspect - NTSC - CCIR 601
Field Dominance - Lower (Even)
- I then edited the footage in a FCP (7.0.3) timeline with the following sequence settings:
Frame Size - 720 x 480 NTSC DV (3:2)
Pixel Aspect - NTSC - CCIR 601/DV
Field Dominace - Lower (Even)
Editing Timebase - 29.97fps
Quicktime Video Settings - DV/DVCPRO - NTSC
My footage looks nice in FCP, however when I burn to DVD it appears stretched, and has interlacing issues in areas where there is movement.
My ultimate goal is to burn my project to a DVD. I sent the footage to Compressor and used the Best 90 minute DVD codec to get a M2V and AC3 file. I then took these into DVD Studio Pro to burn the DVD.
I have a suspicion that I am using the wrong codec ... but I am unsure. Maybe I have a problem with my sequence or capture settings? At any rate, I am looking for the best workflow to get the highest quality DVD. Does anyone have any suggestions?
Thank you in advance!
Jillian
Vid Rate - 29.97fps
Jillian
