thunderMex
I have created a HD movie clip of 3 minutes from footage shot with Panasonic AG-HVX200A. I edited in the same codec and settings as the 1080Progressive 25 frames per second setting of the footage. I am in Europe, home of PAL and 50 frames interlaced video, all that stuff.
Sent to Compressor from Final Cut Pro 7 first as PRO RES HQ 1440 X 1080 25 frames and it is 3.53 Gigs in size as a MOV.
Now I have to find a way to cut it down for importing into a Powerpoint 2007 presentation. One of the problems is that while I am on a Mac with all kinds of codecs at my disposal I am told that the presentation will be transferred to some corporate Windows machine, probably with XP Pro or Vista OS.
I need to downsize this MOV while keeping the 16 X 9 aspect ratio, ensure that it is as clean and crisp as possible while playing in full screen mode going out to a Presentation room video projector from a Windows computer whose processor speed I don't know and memory, etc, and I don't know what video codecs it will have loaded.
I am doing my best to ensure that it WORKS so I have also used Compressor to encode a MPEG-2 version for import to Powerpoint.
But, there has to be more to this than that.
To those of you who have worked in a similar situation can you help me make the best possible choice between file size, and downsizing from 1440 X 1080 to the best choice for a Powerpoint presentation probably done in SD format aspect ratio?
And will using Compressor standard MPEG-2 Program Stream use a codec that Windows will probably play standard?
Thanks for all informed replies!
