I'm having problem printing my HD project to tape. I'm just getting a frozen image on the hvx...is there something I'm not doing right in the settings? Is this even possible?
You can go from P2 to tape, but not from a DVCPRO-HD Sequence to tape. The tape in the HVX is SD, NTSC-DV. It won't accept an HD signal. If you're going from a Sequence to tape (as I assume), you have to do this:
1- Create a new NTSC-DV Seqeuence
2- Drop your finished HD Sequence into the NTSC-DV Sequence.
3- Render
4- Print to tape
