"Play All" command in SP4
Jim Brennan
VHS Member Old Skool
I tried to do a search for this here and on google. I need to set up a play all command for a client DVD. There are 3 separate video files that can be played individually, and now they want a "play all" command.
I thought about doing this the easy way and creating a single video from all 3, and having that play when they hit that button, but I figure I better learn how all this voodoo works.
I understand the basic concepts of scripting, but I get lost both in the Nazarian book and the DVDSP4 manual about EXACTLY how to set up the scripts. The graphic for the tutorial helps to see how everything is supposed to flow, but I can't figure out exactly how to set up the GPRMS and the commands.
Any help would be appreciated....but I don't kiss on the mouth.
Jim
Okay, I got it squared away (in case any of you were losing sleep over my ignorance). The problem lay in my expectation that ALL of the pertinent info would be in one place.
I found most of it in the DVD SP4 user manual (big surprise). I rely heavily on Nazarian's Book, but he makes a lot of assumptions about what you should already know. The manual did a better job this time.
If you go through the "Play All" example in the manual, it should walk you through it. If that doesn't work, you can shoot me a message. After you have done it once, it's pretty simple.
