New_Zealand
is it possible to take a Cinema PL mount lens and change it to a EF mount lens?
yes converting the mount. I have EF but came across a PL mount lens at a very good price (more than half off).
The lens is heavy so not sure if an adapter would work well vs if the lens was light?
Anything heavier and longer than a EF 70–200/2.8 or EF 100-400, I would really think about supporting. The standard EF mount was never designed to support heavy lenses. Heavy still lenses had still cameras hanging off their backs.
But to your original question, it just depends. Largely on how far (and how big) the rear element protrudes. And depending on the lens, there may be a factory/OEM option(like the Canon’s). If possible, I would see if there is an adapter that works with it, instead of converting it. Or even better, if there is a “universal” swappable mount that can be put on it that will allow you to change mounts yourself, at will. I have this on my 17-120.
