Pitching Audio in Vegas 7??
buckman
Can Vegas do normal pitching as in just moving a non-looped peice of audio, up and down and the resulting audio getting longer and shorter (like Acid can without the time-stretching?)
Every time i find the shortcut for pitching CTRL+= etc it seems to turn on the "classic" time-stretch " algorithm on in the properties and the audio pitches up/down but gets warbled?!
I just want the standard pitching where if it goes up = it gets shorter and going down = longer - without any artificial warbling/time-stretch
Is this possible in Vegas? :crybaby:
I think this is what you're asking for - stretch it using ctrl and drag. Then right-click and select proporties. Check the box labeled "lock to stretch"
Well i dont want to time-stretch it at all cus it gets all garbled?
I just want to pitch up and down, like you can in Acid with any audio file (and this is not time-stretched or acidized)
What I should add i suppose is :
I mean pitching +1, +2, +3 etc with shortcut keys as Acid does with the +/- keys, so when you have pad or music under a movie you can quickly hit these and pitch it in "key" with other music..
Ah - got ya now. I've not been very impressed with the pitch shifting using the Sony plug that comes with Vegas. I'd suggest getting a plug-in you like and use that, or do your pitch-shift in Acid (Or other audio editor of choice) and then import it back into Vegas.
