seejay1031
So today, frustrated that micro35 still isn't taking new orders and guerilla35 hasn't updated thier site since well before April 15th, I decided to toy around with some of the concepts using things I had around the apartment. My attempt would be to create a pinhole effect adaptor. Essentially I took a small cardboard box, mounted a paper screen inside, cut a hole for my dvx, cut a small hole on the oppisite side and then taped a few layers of aluminum foil over it, then punched a pinhole in it. After tweaking it a bit I finally got the faintest of images to show upwhen I looked through it, however not nearly enough for the dvx to pick up. After consulting a pinhole countrustion website, I determined that the widest equivelent F stop I could get would be about 190! That coupled with the paper screen would make the exposure almost impossible. If I used something with less light loss, I still don't think it will work. Am i barking up the wrong tree here or do you guys have any great ideas to make this work?
