Photoshop problem: can anyone help?
kyle_doris
hey guys, wondering if you could help. i'm using a new LCD (Samsung Syncmaster 173P) and since i've gotten it i've had quite the issue with photoshop. i've tested this problem out on 5, 6 and 8 and get the same results
basically when i open a grayscale image it looks sepia... at first i thought it might be the color settings since i was using a new monitor (especially with LCDs things can get wacky), but i've since changed them to what i percieve would be the right settings; here they are...
RGB: Samsung - Naturl Color Pro 1.0 ICM (RGB works perfect)
CMYK: US Web Coated (SWOP) v2
Gray: Dot Gain 20%
Spot: Dot Gain 20%
changing the gray to a different setting doesn't seem to change the problem at all...
for a visual this is what i see in every other program (image ready, windows media viewer, dreamweaver, etc.)
what i see in photohop
at this point i've concluded it must be some issue with photoshop itself, it's certainly not a color calibration problem, because i got the desired look in every other program i use.
if anyone know what this problem could be or how to fix it please let me know! this is driving me nuts!
peace.
Re: Photoshop problem: can anyone help?
Do another POST in Premiere Thread as well (as Im sure they will be familar!)
depends on what mode you're viewing the file as in PS. (CMYK vs RGB, etc)
hmmm, like i said, CMYK and RGB seeminly work fine, it's the grayscale that's a problem
