Barry_Green
Moderator
Just passing this on... Pelican cases are great, if a little pricey. I've got a few. For this teleprompter I just got, I needed a case, something around the size of a Pelican 1550, which is also a popular size for use as a camera case for the DVX.
At Cases4Less.com they had the Pelican 1550 for about $100. But they also listed something called the Dosko Sport (Extra Large), same size, for $65. I figured I'd try it.
It's very similar to a Pelican -- same style of bulletproof construction, same style of O-ring waterproof seal, and same pick 'n' pluck foam. The only real difference was the latch design, and this thing latches just as securely as Pelicans, just a different design.
Shipping was dirt-cheap ($7 I think) and nearly instantaneous, as always -- Cases4Less is a great seller!
In short, if you want a Pelican 1550 but want to save about 35% off, consider the Dosko Sport Extra Large from Cases4Less.com.
