Jay Rodriguez
Coffee Member
If you had your choice, which camera would you shoot your next short film on?
Brandon Rice said:Uh... the Varicam
Tlalconetl said:You kidding me? It's like asking, "Which would you rather have? A Ford Mustang? Or a Ferrari Testarosa?" Ferrari (Varicam), bizzle!
Jason Ramsey said:BothBut, if it was HVX or HPX500, then 500 all the way. It's the HVX on steroids. The varicam (even with it's 2/3" wonder-ness) is starting to look a little long in the tooth, with all that is on the horizon.
I just love tapeless too much.
krestofre said:This question is intriguing, and I'd love to know the reason behind it. There's a lot more to take into consideration than just "Ohh, Varicam, shiny!" Who is paying for the shoot? What type of project is it? The Varicam is super-cool and all, but it can only record 720p, right? Do you need 1080? Do you have the gear to handle large DVCPro tapes? If not, do you have the budget to rent the gear or get those transfered to something you can edit? Do you need variable framerates beyond the presets in the HVX? Are you going to be in an environment where P2 would better serve your workflow? Etc., etc.
Without knowing any more about the project than just "what would you shoot on?" I'd have to say HVX. Without the rest of the information I'm less confident that I could turn out a finished piece with a Varicam.
It's not quite that dire—you can edit the varicam's DVCPROHD material natively in most NLEs. So yes, to capture you need a deck (which you can rent for a day), or to hold onto the camera long enough to use it as a deck—but either way the best workflow will be to use the native footage, which has been possible in FCP via FW for years now.TimurCivan said:...Basically, you cant just edit at home, when you have DVCPROHD tapes as your source material. ther will need to be time spent in a Posthouse, doing conversions to HDD, and special editing considerations. (this can cost up to 800$ an hour!!!)
ProLost said:Nthe lens you're likely to use on a Varicam probably costs more than an entire HVX, and for good reason.
-Stu
