Barry_Green
Moderator
... and I have now received confirmation -- AVCI-100 at 1080/60p is, indeed, 200 megabits per second, as verified by the head of the engineers at the Panasonic factory.
AVC-Intra, being designed as a professional master-quality codec, has consistent performance frame-to-frame regardless of the number of frames per second. The actual bitrate per second can vary if the # of frames vary, but the quality of the frame will be absolutely consistent regardless of the frame rate. 1080/60p takes up twice as much bitrate as 1080/30p (or 1080/60i). That's why AVC-I is named as having a "class" of performance. AVCI-100 is not a strict 100 megabits per second, it's "class 100", which is not as high quality as "class 200" would be. The number ("100" in AVCI-100) refers to the bitrate at standard HD sizes -- either 1080/60i (or 30p) or 720/60p. So AVCI-200, in 1080/60i, will be 200 megabits per second; for AVCI-100 in 1080/60i, it's 100 megabits per second. For other frame rates the actual bitrate per second will be proportionally affected by the number of frames. AVCI-200 at 1080/30p would be 200 megabits per second; 1080/24p would be 160 megabits per second, and 1080/60p would be 400 megabits per second. Similarly, for AVCI-100, 1080/24p is 80 megabits/sec, 1080/30p or 60i is 100 mbps, and 1080/60p is 200 mbps.
So, harddrive, your assumption was incorrect. If you've made this speculation on any other forums, it sure would be nice of you to go back and correct that so that the misinformation is countered and false rumors don't gain any traction.
