CAMCORDERS: PANASONIC HVX-200P - A couple issues - HELP!!
PatRat
I have 2 PANASONIC HVX-200P cameras.
One of them I just bought used. Seems to work fine.
My existing camera has the composite cable plugged into it and I use it to
feed a Blackmagic ATEM. Works perfectly without issue.
I unplugged the composite cable from the working camera and plugged it into my “new” camera.
I have no video signal coming out.
Seems like I remember reading some time ago that one of the settings controls making the composite port active. If so, does anyone know which one controls this?
I also tried using a SVHS cable into an ANALOG to HDMI Converter box
as well as trying a RCA video cable to the same converter box (not at the same time!) and got no signal that way either.
In that situation I do not know if the converter box is even working correctly.
Would prefer the composite cable.
Can someone help me figure out why I have no signal?
I aslo want to change the settings in the "new" camera to match the existing one.
SETTINGS
SCENE F1
--- I cannot change V DETAIL FREQ from THICK to THIN
OTHER FUNCTIONS
--- I cannot change OPERATION from 01877H to 0539H
RECORDING SETUP
-- I cannot change 25M REC CH SEL from 2CH to ACH
---I cannot change the 480i REC MODE from DVCPRO50 to DV.
I hope someone here is familiar with this camera and how it works.
I don't remember much about the camera anymore, but I'd factory reset it and see if that helps (this is also common in multi-cam setups where you want to start from scratch with everything to make sure it's all on the same page).
Video output menus are pretty straightforward (check AV IN/OUT or somewhere) and you'll eventually find it by looking around and can cycle through the few available options.
If no signal is appearing through anything, the outputs are fried which is not uncommon for old cameras (everything eventually expires at some point, naturally or through an action).
I've never used that camera, but this is probably the camera's HOURS meter, If so, then you can't change it. It is like an odometer on a car and it tells you how many hours the camera has been powered on. One of your cameras has been used 3.5x more than the other. The only way to change that would be to let the camera with 539 hours run for 56 days straight. Then the meters will match. Obviously, that is not advised.
