Panasonic HVX-200 Native Resolution
Bob Thanks!
Great info!
it gets me further along the road to knowing when to buy in and why .
i am very interested in seeing all these cameras do thier thing while projected digitally .And equally interested in seeing a PROJECTION PREFORMANCE TABLE !!!
Jan does this sound unreasonable ?
For the dvx100a I was able to see (subjectively speaking) a digital projection
which I term "acceptable " on a 20 foot screen and 30 feet .
Again this projection tab le could be produced by Panasonic(Jan) ,Adam or Barry .
I wish there were specs on possible projected line values that could be published with the rest of the camera specs .
Theaters ,even small ones are still an important venue for work done on the sd and sd (uprezed ) as well as true hd motion picture work
be it feature or documentary .
Thanks again for the response guys .I do appreciate it .
Cheers
Bruce
Hi Toke,
It was easy to see A/B on a 9" BVM HD monitor so we didn't record the Z1U. I know there will be plenty of side-by-sides in the coming months. Comparing the HVX and Z1U is like comparing the DVX and PD150, they're different tools.
The HVX charts we shot are all on data DVDs. Everyone in post is really busy with the holidays right now. However, if someone wants to host the HVX charts I may be able to get some tiffs exported in early January.
I.
Thanks Illya! BTW, any news about new 35mm* screening tests?
[(for who doesn't know LINK) *film-out from HVX footage]
If Panasonic does not want to give away the res of the chip, how about telling us the actual size of the chip? A horizontal and vertical size is needed to calculate an accurate DoF and object size paired with a lens. Film is easy....ASC manual. Digital seems to be difficult in getting the info. The reply "it's a 1/3 inch chip" just doesn't cut it.
Here's a rough estimate of the size of the chip:
The layout is 16:9
Squareroot( (16x16) + (9x9) ) = 18.3575597506858192984917195187072
The diagonal is roughly 18.358
From here, everything is a ratio of all the numbers.
1/3" x 16 / 18.358 = 0.2963" = 7.526mm horizontal size
1/3" x 9 / 18.358 = 0.1634" = 4.151mm vertical size
The numbers amy be a tad off, because the chip diagonal may not be exactyly 1/3".
Bob Diaz
A resolution comparison was done and the results were posted on DVInfo Net. I'm not sure how accurate these numbers are so I'm not making any judgements, but I would love to know what you guys think about the following info:
Resolution Comparison:
Canon XL H1 from Shannon's chart http://www.cinemahill.com/hidef/xlh1...s/IMG_0115.jpg
800Hx650V progressive
800Hx800V interlaced from German magazine, not from Shanon
Panasonic HVX-200 from Kaku's test http://home.arcor.de/martin.doppelba...rts/0088YP.png
625Hx600V progressive
JVC HD-100 from Martin's chart http://home.arcor.de/martin.doppelba...e Blende.jpg
700Hx525V progressive
Sony FX-1 from Martin's chart http://home.arcor.de/martin.doppelba...P_Off f4.png
650Hx775V interlaced
JVC HD-100 from Martin's chart http://home.arcor.de/martin.doppelba...e%20Blende.jpg
Sony FX-1 from Martin's chart http://home.arcor.de/martin.doppelba...P_Off%20f4.png
Because the results come from 3 DIFFERENT sources, the numbers are questionable. We have 3 different test setups and the exact same camera would yeald 3 different readings.
Untill Barry can test all 4 cameras under the exact same test setup, we are jsut making wild guesses.
Bob Diaz
Indeed we are. You have to remember, Kaku himself was quite confused as to how to perform the test, he admitted it himself, he had no idea what he was doing when it came to the res test and needed assistance.
Numbers are way off, because the way CCDs are measured they're nothing like 1/3". No 2/3" CCD measures 2/3" in any dimension; no 1/2" CCD is anywhere near 1/2" in size, and no 1/3" chip measures 1/3" at all.
You can find various resources on the net to tell you exact dimensions on almost all CCD sizes; panavision new zealand has a calculator for that too. Nobody seems to have a published size for a 1/3" 16:9 chip though. My best guess is that it would measure about 5.25 x 2.95 mm. And yes, that's for the Canon, JVC, Sony and HVX -- they're all going to be the same size.
Barry, no suprise, you are correct about the chip size. The convention of referring to CCD as 2/3" etc comes from the days of tubes when the outside diameter of the tube was approximately that size (others were 1 1/4" , 1" etc) . the active size of the sensor has always been much less (even in the tubes) with 2/3" having a diagonal of approx 11mm which is less than 1/2" .
Bill Turner
Schneider Optics
Century Division
