I have some questions about what sequence settings I should use in Premiere pro at work, when I have shot the footage on a panasonic hmc41 (the euro version) in 1080/25p.
1.
When I add the footage to my project and drag one clip down to "new item", it creates a new sequence. If I then go into the sequence settings I can see that it is 1080i and either upper or lower fields first (can't rember right now
). When I add footage to the timeline it gets a yellow render bar over the footage.
So now I'm guessing that this the same as choosing the AVCHD 1080 25i (50i) in sequence preset, or what?
2.
But on the panasonic hmc41 it says on the camcorder screen that it is recording in 1080/25p, so should I then use the AVCHD 1080/25p sequence preset?
I also found this:
http://pro-av.panasonic.net/en/sales_o/avchdcomp/AG-HMC40.html#anchor001
Here is says that for 1080/25P you should choose AVCHD 1080p25.
When I choose AVCHD 1080p25 sequence preset and add my footage to the timeline, a red render bar appears over the footage
So I ask which method is the correct one and what is the difference?
And what role does the yellow and red bar over the timeline footage play?
Thank you for your help
Best regards
Lars
1.
2.
I also found this:
Best regards
Lars
