pal 24p in compressor
vincent.a
Hello
i don't know if i'm in the right section.
so i've made a movie in 24p ntsc that needs to go both ntsc and pal
for the ntsc part it's easy but for the pal part. howcan i get with compressor a 24p pal file as when i choose the pal it only let me in 25.000 fps.
i'd really appreciate if someone can help me out
vincent
Doing a Pal Conversion requires some trickery with the audio as well, since Pal film is actually sped up to 25FPS.
There are tools and guides out there available for Converting DVDs that are 23.976 to 25 FPS (including audio sync) for windows, however on the Mac you'll have to do it manually.
http://forum.videohelp.com/topic140171.html
You'll need to use compressor to export your video at 25 FPS mpeg-2 and then you'll need to process the audio with an external application that can speed up the audio to match 25FPS.
