PAL 16:9 without Pollarbox. How?
etrust
Hi,
I'm using Vegas 9 Pro. My original Footage is 1980x1080.
I must render my video to Mov, Pal, 16:9, without Pillarbox.
Which Parameter or Settings should I change under rendering settings to get this configuration?
Thank you
There's no render setting for this. PAL (and NTSC) widescreen is slightly wider than true 16:9, so you will get the thin black bars on the sides.
What you should do is change your project settings to PAL widescreen, then go into pan/crop on each clip and choose "Match Output Aspect."
Hi i can not find "Match Output Aspect."
and i have now more than 200 elements. How to apply this to all without change specific settings on some elements?
after clicking on pan/crop you simply right click on the screen where you'll see restore etc..."Match Output Aspect." is there as well
