P2 Viewer Plus -- p2 drivers updated
Barry_Green
Moderator
Saw on the Panasonic PASS site that they've introduced some updates to P2 Viewer Plus.
The notes say:
•Note: P2 Viewer Plus
When you played back P2 clips with USB of P2 equipments by P2 Viewer Plus, the speed of the process was improved. (June 5, 2013)
•Notice: IEEE1394 Driver
Installing in Windows 8 is not supported. Writing onto P2 cards using IEEE1394b interface under Windows 7 is not supported.
•Notice: CardBusDriver
The P2 card driver needs to be installed for each card bus slots.
When installing Driver software to a personal computer that has two or more card bus slots, please insert the P2 card into every slot.
What I take it to mean is, if you're using P2 Viewer Plus to play back footage on a Windows machine, through a USB2 card reader (or a camera connected by USB2), that the playback speed has been "improved".
Note for PCD20 users though, if you're using Windows 8, firewire connection isn't supported, and for Windows 7 users, you can't write back to a P2 card in a PCD20 that's connected by firewire. Two good reasons to just ditch firewire on the Windows platform and use USB instead.
