Spec-Comm said:By far, the fastest way to transfer to a PC is using this adapter:
http://www.spec-comm.com/scpci-p2.php
brock2621 said:Thank you very much david... i will order this weekend. Also, is raylight really the cheapest way to read p2 files? Good grief... you think someone would come out with a better way for a lot less. I'll be paying 200 for merely seeing my footage! >:/
If USB or FW is your only option, using the Camera, as mentioned, or the P2 Store as a bridge works well. This all depends on your work flow.
Yes, but impossible.MrPolarBare said:A front-loading solution would be much better.
MrPolarBare said:One of the main drawbacks of that solution is that you need to insert the p2 card into the pci slot on the BACK of your computer. A front-loading solution would be much better. But, I guess everyone's computer setup is different.
Mike McLin
Spec-Comm said:The next best option is the P2 Store, if the speed is acceptable (USB2).
I believe it will, because they claim 32-bit PCCard/CardBus support -- that's the crucial requirement.mano secreta said:
