petelms
Hi.
I bought 2.5" firewire HD, case for it and USB battery solution, but for some reason it's not working with my camera. :crybaby:
When I connect the HD via firewire and then power the hd via USB battery, switch on the camera... it doesn't seem to recognize the harddisk...I use the 1394-host mode...it only gives me option to use setup, as you can see in the picture below...
This is the HD case I bought: http://www.mapower.com/Product.asp?CateID=10&LineID=9
Do I need to format the HD with computer before using it with camera? I tried to use the harddisk with computer and it works with any problems...
Any ideas what is wrong? :huh: I don't understand...I have tried everything and it doesn't seem to work...
Does the HD have to be in slave or master mode? When I bought the HD I couldn't find any jumpers in the box...so it's in the master mode by factory defalts...
Please, help! :huh: I'm getting desperate.
Thank you!
Thank you!
