P2 store replacement
Daniel Leite
Would this work?
http://www.c1au.com/microtablet.html
C1 microtablet is powered by a 1GHz VIA Eden processor and features an 80GB hard drive, 1GB of RAM, an 8.4” TFT LCD touch panel, three USB ports, a PCMCIA slot and a DVD-RW drive. The device has a three hour battery life, weighs in at just over two pounds and retails for $1,900 USD.
I don't see why it wouldn't. You should be able to install the P2 drivers on that system, and then P2 cards become mountable. You can drag the contents over manually, or use a P2 offloading utility.
My only concern is the amount of disk space left after XP etc. are installed. A larger hard drive would be nice, but you should be able to swap in a larger notebook drive if you want.
