P2 Import Questions (clip names, log/cap, resolution)
fgiraffe
I'm used to using Log & Cap in FCP for DV tapes, and I am starting to use the P2 Import window to bring in P2 clips.
I like having the clip name be automatically created by concatenating the Description, Scene, Shot/Take and Angle fields. A few minutes of poking around and some searching leads me to believe that the P2 Import window does NOT have this function. Is this correct? If so, WTF?
What are some Best Practices for naming P2 clips in large FCP projects? The system I have been using for tape project ensures each clip will have a unique, meaningful name (e.g. NC 051207_Intvw_13_Wide), but it does rely on the concatenating. Having to manually type in the new clip name when every clip is imported would be teh suck.
And where is the Description field in the import window, anyway?
It also looks like you cannot log a clip without capturing/importing the P2 clip. Is this correct? This would be really handy when you want to burn through and log your clips but do not yet have the storage available for all of them.
Lastly, it looks like you can only import full res clips (in this case, DVCPro HD 720p24)? Do you have to use the media manager to create Offline RT HD clips after importing them all?
Any advice or pointers appreciated, thanks in advance.
(JDS'll love this) :D
Use Raylight. Raylight will import the clips and append the User Clip Name to the front of the clip. FCP alone doesn't do that.
For info on what the user clip name lets you do, see this article:
http://www.dvxuser.com/V6/showthread.php?t=98159
Of course, using Raylight will also let you have access to all the metadata, and it also lets you bypass the whole Log & Import window completely too...
Thanks Barry. The article is useful for future shooting, and does a great job of demystifying the P2 names. But I still have about 1500 clips already shot to log/xfer that do not have User Clip Names.
I just do not understand why the P2 Import window would be crippled compared to Log & Cap.
I'm still on FCP 5.1.4 BTW, which is sorta obvious.
Won't the free Mac P2 Viewer from Panasonic allow you to set the User Clip Name? I have not tested it myself. If you did that then the automatic clip naming of Raylight would work for you. Raylight will also organize clips into folders based on the name of the P2 Card and the "Program Name" metadata item.
Also it is not neccesary to name clips at Log and Transfer- because you don't need to watch as they are being transferred so there's not a big time saver here. Once you have them in a bin you can start organizing and naming clips knowing that the transferred quicktime file names match the camera originals. Personally I prefer to maintain the original clip name given by the camera for easy reconnect when needed.
You can use a lot of the other bin fields for your names like log notes description, scene, shot/take etc, and then drag that column over so you can see it. Also reorganize by bin, etc.
Noah
Ahh, so you do not even review the clips when you import them?
I can see how it is not as crucial to name P2 clips as it is for tape clips, since the P2 clips already have a (relatively) unique (if not-entirely-helpful) name.
My tape projects rely heavily on clip names for organization, but it sounds like for P2 I need to learn to rely on the other FCP clip property fields.
My practice has also been to never rename clips, it can just get too big of a pain when you need to re-capture.
For me the workflow is just ingest everything- it's different than with logging and capturing tapes because that take a lot more time. Logging and transferring is much quicker and as the clips are already broken down shot by shot there's not much to be gained by doing work at the transfer stage. Unless of course you are low on storage space and planning to not transfer all clips.
Noah
I don't use all the clips. REC and PAUSE a million times a day creates a ton of garbage clips in the P2 files over the course of a day. The process of going through all those in the Log and Transfer (L&T) helps to sort it all out. (FCP 6.0.1) I did pretty much the same thing in 5.1.4 using P2 Import.
Just my anal workflow, but I clean house prior to ingest. I also take the time to label the clips using the short cuts provided by L&T window.
