I wanted to see what some of you veterans suggested in this scenario:
Outdoor wedding late afternoon as the sun is starting to set and thus the color temperature is changing a lot during the event.
The trick is that one camera is on a stationary tall stand locked down because I use it for a safety wide shot but also for a sort of time lapse effect. So once it's atop the stand I cannot move it nor perform a manual white balance because it will ruin my time lapse effect.
The other cameras can be manually WB just before the event, but not the stand camera.
So last time I set the stand camera to preset 5600K and manually WB the other which ended up causing them not to match (as expected). I figured I'd adjust the stand cam in post to match the manual WB on the other cam. After syncing up the footage I wish I'd just set everything to 5600 preset like I often do, but knowing the sun would be changing didn't this time.
What do you guys recommend?
