OSX Image Capture hangs on importing images!
eco_bach
Frustrating. On a half full 128 GB card am only able to import a couple .jpg images. The remainder, mostly raw(.cr2) and .movs, hang on import.
Does anyone know a workaround? I guess this problem is camera-firmware side as I have tried 3 different software apps, image capture, image browser and EOS utility, with the same result. On repeated tries was able to import just a single raw file, but subsequent imports just caused the application to hang and-or throw an error.
Also tried bootcamp, mounted my CF card and tried copying images. Was able to actually copy 3 raw files before the same things happened,
Make a new folder on your hard drive and then copy the ENTIRE contents of the camera's memory card into that folder. Now try importing all of the pictures and movies from that folder, not from the card.
If I could copy the contents of the CF card to my desktop there would be no issue!
As far as i can tell this is another firmware bug with the 1DC. May have something to do with the sheer number of RAW files, a 128GB CF card almost full.
After using my 5D2 to access my RAW files, I deleted them, then popped the CF back into my 1DC, was able to successfully retrieve the remaining 4K .mov files.
