ddixon
I posted this in an older thread, and it seems to have gotten lost, so I'm trying again with a new thread:
I'd appreciate opinions on this little test I've done (<2 min.). Using an AT 4053b, it compares several recording options, two for in-camera use and two for voiceovers, etc.:
1. AT into Canon directly - xlr mic level
2. into the Canon via a MixPre - xlr line level
3. into GarageBand via the MixPre - tape out line level miniplug to MacBook line input
4. into GarageBand via a Mackie Onyx Blackjack usb interface ($149 on sale)
The Canon records 16-bit linear PCM and GarageBand is recording 24-bit and saved as .aif. The 4053b was about 12 inches above, and pointed directly at, my mouth. The low end rolloff was NOT engaged, either on the 4053b or on the MixPre. All I've done to the recordings is try to even out the volume levels as best I could.
My opinion? I'm underwhelmed by what the MixPre adds. Either this is not a setting that shows off its capabilities, or I have it set up wrong, or my ears are not discerning enough. Should I be getting more bang for the buck from the MixPre?
Recording something other than dialog might be a little different, but dialog is 90 percent of what I do. And Vimeo does flatten everything out, but it's slight enough that this is still useful, I think.
Thanks for any comments!
