one monitor per camera?
ruester
I want to get two cameras, do I need a monitor for each, or can I put them on a switch to flip between the two?
I wanna get the Panasonic BT-H1390Y 13 Monitor, is there a model that is similar but costs less out there?
Re: one monitor per camera?
That monitor has a separate composite and s-video input, so you could ostensibly hook up two cameras to it directly, and use its own input switch to determine which camera's image to see.
Awesome! Thanks.
I know I should get two monitors, but do you foresee any problems with a single monitor setup? Any suggestions?
You will be completely fine with just one, unless the two cameras are miles apart. Most field monitors have an A and B input to switch for that very reason. As well you are asured that you can campare the to images correctly, without worrying about the monitors being calibrated.
