Avenger007
Hello all,
I am between setups on location and trying to calibrate this Brevis but it seems either the unit simply won't adjust to what I need or I am not properly setting it up. This is the 2nd shoot I have received a Brevis and I am still not happy with the results from the last one. I can't access instructions (other than a few simple videos from google) because non-owners don't have passwords to the site.
The corners are soft and the focus just isn't tack sharp. Also the lens barrel markings are off still.
Is there a more efficient way to adjust collimation and GG focus?
Here was my process -
Entire system already cleaned part by part. Fully Charged
Brevis fully slipped onto Macro and Aligned using 90% guides in camera.
Did best to tighten 4 screws in order of aligning the GG frame in center.
Attached my Prime and stopped down fully to see GG. Set HVX to F2.4
Focused to GG (or at least what appeared to be sharp overall). Settings were Z73 and F09.
Is the focus enhance good for this application or does it affect results?
Then I measured 1 foot from what I guessed was the location of the GG to a text chart in front of camera.
Loosened 4 front screws on Brevis and adjusted lens mount until chart appeared in focus at 1 foot on the Lens barrel.
I still can't tell if I can truly trust the barrel markings. What is the actual location of the ground glass as well. Is it exactly in the center of the Brevis?
And what is optimal F-stop to set the HVX? I have mainly stayed at 2.4/2.8
Here is the complete setup:
HVX, Brevis (non-flip), Zeiss Planar Primes, Marshall HD monitor
btw does anyone have a PDF or tiff of a resolution chart? I can get to a Kinkos by call time and get it blown up. That would be major help. Thanks for any tips.
