Just inherited 2 Lowel Pros with stands. Warning on side to read the instructions, which I don't have. Is there anything I need to know, beyond the obvious "mount on stand, focus, adjust barn doors, turn on, etc...."?
Thanks. I've also been told: point it away from people when you turn it on, in case it explodes. And let it cool down for 10 minutes before you move it.
Pretty much the same stuff you'd do with any tungsten lights. I was changing a bulb in a Lowell Pro once, the grip didn't realize what I was doing, plugged it in and turned it on. They get to about a gazillion degrees before God hears about it. Ouch! Good little lights. Great for hair lights, accents, etc. Enjoy.
If you have them on for a while, then turn them off, are you supposed to wait before you turn them on again? I had em on 10 minutes, off 10, and the bulb blew. But it's an old bulb, so maybe coincidence?
There are different grades of bulbs, and also different color temperatures. The higher grade bulbs cost twice more but last 4 times longer in hours of usage. Also, cheaper consumer bulbs with the same mount sometime have 2900 deg K, when you should usually have 3200 deg K to be consistent with other fixtures. I have 2 pro's and I have never waited to turn them on. I always flick them on/off repeatedly to gauge shadows. I like pro's because you can put more accessories on them than a Ford Crown Vic. The only cautions with pro's is high-heat and angle of usage. Never tip up or down greater than 20 degrees angle. The bulb will melt and blow.
