Old HMI head with new ballast
Eimulis
Hi, is it possible to use old Sirio 4k HMI head and new arri or similar ballast
Will it be enough just to make an adapter cable?
post-73760-0-49898500-1533815990.jpg post-73760-0-59539100-1533816327.jpg post-73760-0-93172300-1533816318.jpg
The head appears to have an older LTM connector, which is rather strange since the 575's and 1200's came with VEAM connectors like you need for this. If you have the tools and knowledge, you could likely swap out the connector for less than the cost of an adapter, but either way you would need to make that conversion. Once that's (correctly) done there's no reason it shouldn't work.
