Throwback
Have just received a MK 012 today - the movie set version - and have spent the evening putting it through its paces on a boom. Generally pretty much as expected (and handling\wind noise slightly less than feared), but have been surprised by the additional self noise introduced by the low-cut pad included. It is surprising that such a simple device can add this noise (you can see two components - one at least a capacitor - through the transparent cover). The noise is sufficiently noticeable that I wouldn't want to use the low-cut pad, and, as I boom via a Sound Devices MM-1, I have a good alternative 80hz low pass filter, but - as I would prefer to cut the low frequencies at the mic and, even, be able to use both filters on occasion - I wonder whether others have listened closely to the mic with and without the low-cut pad and, if so, have noticed the unusual noisiness of the pad (I don't have the same problem with other mics). If not, l'll assume the components in mine are faulty and send it back to Germany (it came from reputable Oktava-online in Stuttgart) for a replacement. Cheers, Roland.
