Hello All,
I am editing a number of short segments in Adobe Premiere 2.0, which I'm kind of new to. I have used Adobe Premiere 6.0 and am also pretty competent with Final Cut Pro.
I'm wondering if there's an easy way to edit a project using offline-resolution (320x240) footage and then re-capture everything into full-res DV once I've picture-locked. Final Cut does this quite nicely within one project, but it doesn't seem that Premiere has this functionality, and I'm stuck working with Premiere on this one. Worse yet: the project is due on Monday and I've already begun editing using full-res DV footage. Now my hard disk is almost full and I've still got hours of footage to sift through.
I've already read the following thread (http://www.dvxuser.com/V6/showthread.php?t=32566) and see that I can capture low-res if I create a new project for the offline version, but I'm unlcear on how to re-capture everything for the online edit once I'm locked. Is there any way to change the project settings once you've started working in it (so you don't have to create a new on-line version of the project)? Ideally, I'd like to do that and then re-capture everything into offline resolution to save disk space. I'm editing on a laptop.
Many thanks for any help you can offer.
