Odyssey 7Q+ unresponsive touch screen?
Zak Forsman
Major Contributor
My Odyssey 7Q+ has developed an issue where it pretty consistently needs to be booted up twice in a row because the touch screen will be unresponsive the first time. This is only after it's been powered down for an extended period of time (overnight, etc).
I don't know if I can attribute it to a firmware bug or not, but I do keep it updated with the latest. A bit of history: For the first couple months I owned it, this never happened. But in July I first ran into it. At the time I attributed it to the fact that Convergent Design lists an occasionally unresponsive touchscreen under "known issues". But since then, as i said, it's become routine that it won't work on the first attempt. And today, I had to boot the unit up four times before the touch screen would work. So i worry I've actually got a hardware issue that's getting progressively worse.
Anyone else run into this?
Press the F1 lock button on and then off. That makes my screen responsive every time when I have that issue.
