Odyssey 7Q calibrated
Baddgsx
I finally found my calman license and got the eyeone pro up and working correctly. The grayscale was way off. Green and Blue were much higher than red so to compensate i brought both down. Some RGB controls on the lower end would be awsome for a future update. then we can really dial in the monitor better. The color controls needs at least a hue setting. just color doesnt give us much control. Can you put a CMS in the odyssey Mitch?
sat 40
contrast 50
rgain 100
g gain 96
b gain 96
back light medium
color gamut rec709
color after calibration.jpgcolor before calibration.jpggrayscale before calibration.jpggrayscale calibrated.jpg
my eyeone pro meter was having trouble in the 0, 10% and 20% marks , im thinking due to OLED technology getting blacks sooo low.
are the setting you list at the top of your post what you set the odyssey to after testing it? if so, would that work for ALL odysseys, or is each one going to be "off" in different ways?
The difference between the less expensive specrophotometers and the $1000 variety is the ability to measure under 20% accurately. You can't expect anything the Eye one Pro reads under 20% to be reliable.
i think it will work for all odysseys since they all use the OLED display. the settings i posted are the post calibration settings.
We are evaluating the possibilities in enabling a more involved calibration system for the Odyssey7Q OLED panel.
awsome Mitch!!! Then you guys will have the perfect recorder/reference monitor. Nothing tops OLED technology.
Thanks,
Chris
OLED is starting to become more affortable and perform the best visually. CD engineers are genius' for putting OLED panels in All 3 of the odysseys. They achieve better blacks and better ANSI/native contrast ratios. the pixel responce is faster aswell. once they fix the cms it will dial in perfect.
If you want color correct model, then does that have to be OLED tough.
I wouldn't mind trading off OLED or touch screen, or those fashionable and probable future upgrades such as HDR and high nits screens, to have one model with better calibration possibilities and 1920x1080 screen.
Better power options too, please. We'd be fine with 7,7" or 9".
TVLogic VFM-058W have been hugely successful with focus pullers and other camera crew for it's FullHD screen and rather accurate colors. SmallHD seems to found success with their light weight and slim 50X and 70X series, as they can be powered LP-E6 or NP-F batteries straight out of box, include good scopes and nice long all around hoods, and calibration possibilities.
