O-T-G drive
gdot101
Has any one seen these before
and can it be used with this on
the hvx200 to offload the P2 cards
it looks like it should work from all the info i have seen about the on the go drive on the site.
Any OTG device should be able to work; just be aware that the HVX doesn't supply any "bus power" so you'll either need a battery-powered hard disk enclosure, or you'll have to plug it into a wall socket.
Okay, great . My other questions was about the usb to firewire cable will that work. Also hat advantage does firewire have over the usb in regards to the O-T-G drive off loading
