Nuendo vs. Pro Tools
Hmm.. What do you really mean by an "industry standard"? Does that purely mean that everyone is using it, or are there serious compatibility issues and things that Nuendo just can't handle? Because right off the bat I can't think of anything that would be a major decision maker for me between these two.
Dmitry Kichenko said:
So, function-wise, Nuendo is a better deal compared to Pro Tools LE, correct? Hmm.. Nuendo seems like a more flexible option for me right now, and one I don't have to study too much knowing Cubase well.
Ummm... the question is, what features do you NEED? Then find out what software bets suits them...
The upgrade to Nuendo gives you advanced surround mixing capabilities and some advanced tools for use when doing post work specifically with film. There is a PDF on the Steinberg site that details the differences.
By standard, they mean that the majority of studios and post facilities use a PT system, although Nuendo has been gaining ground, albeit very slowly.
I have used OMF export from FCP into Protools HD with no problems.
Dimitry:
If you want to take your audio and have it mixed by a pro there is probably a 90% chance they will ask for your pro tools session. If you have it, it will just work. If you have a session in some other format they will curse you.
Nuendo has just about all the features of Protools HD, minus the expandability, and the ability to interface with some really pimp and hideously expensive control surfaces :)
Wow, I should indeed consider selling all my property and buying one of these ICON consoles.
As to the actual choice, I think that a Digi 002 + Pro Tools combination would work best in my case. It's a *sigh* standard, 002 can operate as a standalone mixer, it has good preamps..Hmm.. The only trouble is using the control surface and the audio unit under other DAWs. Right?
It's possible (as an audio interface, I think NOT as a control surface)... but I've heard occasional bad things about the drivers for use with other software. 'Though most of that has been on the PC side.
I've never used Nuendo, but it seems that if you like Cubase it should suit you well. I use ProTools, which works for me and is especially strong for audio, and I think considerably worse as a sequencer. Doing film work, it seems to me that the most important difference to you between PTLE and Nuendo would be surround capability, which, of course, Nuendo wins hands down if that's an issue for you.
I have a 2 Digi002s (1 surface and 1 rack) and (after some initial problems with the power harnesses) have served well and reliably for years. I can highly recommend either.
But, consider all your options. The MOTU 828 MKii is a well-respected unit, and Digital Performer is also an attractive platform. The MOTU Traveler has a certain blend of portability and features that can't be matched. The new Mackie Onyx-based interfaces haver some interesting features and great preamps.
I've never been fond of M-Audio interfaces... don't take my word for it, and I've never touched a ProjectMix... but check carefully about reliability and such!
The ICON is indeed pretty nice, but hard to carry....
I disagree with this whole "PT is industry standard" thing - there are more systems out there than PT, and although its most used, I dont think it can be considered standard anymore, unless you are looking at the highest levels of production.
Another thing to add is this whole OMF business: Cubase doesnt do it, Nuendo does. HUGE difference. And if you take your audio to a post house, they'll prob ask for an OMF, not a Pro Tools session.
So anyway, those are just my thoughts. Personally, I back Nuendo because its a younger system and I dont believe in monopolies in an industry, it just causes problems and leads to users paying high prices for normal products.
I use MOTU hardware and love it. I've had nothing but bad experiences with M-Audio, but I run Macs. My PC brethren tell me that the M-Audio stuff works good on their systems. Everyone I know who has tried to run M-Audio gear on Macs have had problems (mostly with the audio drivers and latency).
Matt
timepter - both Cubase and Nuendo do OMF. Both versions of OMF, 1 and 2. I have succesfully exported OMFs from Avid, both embedded and with references, and had no problems importing those into Cubase. I do remember I had problems importing into SX2 a while ago but it's all good now.
I did have problems importing back into Avid, but after doing a search I have discovered it's an issue with both Nuendo and Cubase and just has to do with Steinberg, I presume, not entirely matching the OMF standard somehow. In any case, using AV Transfer fixes the issue.
The differences between Nuendo and Cubase are when it comes to AAF. Cube doesn't support it yet. I bet it will in SX4 but I wouldn't say I'm in a tremendous need for AAF. It offers the same options as OMF 1.0 so I don't think it's as advanced of a format as the latest version of OMF (I believe there is OMF 3.0 in the works).
At 1 point your statement was true but when Digidesign released their LE product line (about 5 years ago) they truely became the industry standard (defined in terms of actual sales). When Digidesign purchased M-Audio (over a year ago) then the game was over.
So consider this:
You can get into a pro tools system starting at around $300 and you have entry points at all levels, $500, $700, $1200, $1800, $2500. Then you take a serious jump to get into the HD level, $9500 on up.
You also have support, upgrade pricing, compatability with a wide range of products/plug-ins and the assurance that everything has been tested. When making a business purchase many times we overlook the things that are equally important in terms of keeping your business up and running.
Now take a look at each products feature set based on what you need and weight your options informed.
Pro Tools IS the industry standard. The industry is just that. Those of us actually doing real work in the entertainment industry. If you are just doing stuff for fun, or for friends, and doing everyting yourself, then don't worry about having the industry standard. If you actually want to get work in the industry, you'd better go with what's the industry standard. Otherwise you may have issues with people wanting to work with you again. That's speaking from personal experience.
Yes, it looks like I'll keep Cubase around for the music composing and Pro Tools LE for the audio work for film.
Also, I've heard that Logic can be used as a front-end for the Digi hardware under OSX. Is that true? Because if it is, I could comfortably use Logic for music and Pro Tools for mixing, mastering and film work.
I have done plenty professional work on Nuendo, including mixing work from other studios, and sending edited sound to other studios, stereo and 5.1 - no complaints.
I believe the Logic bridge got dropped pretty recently (With version 7 perhaps?). If I remember correctly it was for using TDM (not LE) hardware with Logic. Now that Apple owns Logic, its unlikely that they will be doing very much to allow it to be used with competing software.
I'm not entirely sure why they would drop the support.
I don't think it creates any competition for Apple, quite the opposite. It brings Apple new customers who want to use Digidesign hardware but also have MIDI support. In fact, by having Logic compatible they're creating competition for Digi forcing them to work on that MIDI support parody in Pro Tools I read about .
Yes, it's possible... I often use a Digi002 with Logic. Again, it doesn't work as a control surface, only as an audio interface. Unless anything has changed in the latest Digi drivers...
btw, Logic 7 also has TDM support.
For a low budget control surface I have a Mackie Universal Control next to me at my editing desk and really like it, great functionality.
Matt
Matt
IMO that's middle or high budget. For a low budget it would be Behringer BFC2000.
EDIT: I don't think the Digi 002 control surface provides that many advantages over other similar surfaces, except for maybe tiny LCD displays. So to me it looks like the Digi 002 rack + a PT compatible control surface, even BCF2000, is a better choice. What do you think?
Trust me, those little LCDs are FLIPPIN handy - when youre mixing a big project, and flipping through the banks to find a track, they save your head from exploding at crunch time. For me, they're probably one of the most important features on a controller.
Well.. I'm not sure those justify the the extra thousand dollars I have to pay for the Digi 002 as compared to the rack version.
